[Gdal-dev] Negative values returned by GetRasterYSize()
Roger James rogerjames99 at btinternet.com
Tue Jul 8 05:51:24 EDT 2003
Is there a convention for raster orientation in GDAL and if so is it
stated somewhere.
I am having some trouble with images that return negative values for
RasterYSize., and could do with some guidance on how to interpret this.
I assume that a negative value means that the raster should be
accessed/affined with a bottom up cell (pixel, display etc.) co-ordinate
system? If so I think this should be documented.
If it already is then please accept my apologies and tell me where to
look.
Is this handled consistently. I am getting images that display the right
way up but when I use the affine co-efficients the y geo co-ordinate is
flipped.
I realise that this is a problem in my code but I just cannot seem to
get the correct mapping between the window co-ord system and the image
co-ord system.
Thanks.
Roger
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20030708/05ad24e6/attachment.html
