[Gdal-dev] Negative values returned by GetRasterYSize()
Frank Warmerdam
warmerdam at pobox.com
Tue Jul 8 08:23:57 EDT 2003
Roger James wrote:
> Is there a convention for raster orientation in GDAL and if so is it
> stated somewhere.
> I am having some trouble with images that return negative values for
> RasterYSize., and could do with some guidance on how to interpret this.
Roger,
To clarify the GDALGetRasterYSize() function, or GDALDataset::GetRasterYSize()
method is returning a negative value? This should never occur, and persumably
indicates a buggy format driver, or a corrupt dataset. Can you provide an
example?
However, if you mean that the y pixel size component of the geotransform is
negative then that is the normal convention for georeferenced images.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
