[Gdal-dev] GNUmakefile cleanups (libtool related)
Alessandro Amici alexamici at tiscali.it
Thu Jul 10 15:52:34 EDT 2003
Frank,
i investigated a bit more the possibility of using libtool in the gdal build
and i think i can counter most of the comments you raised in your last email
on the subject. in the meantime, i managed to actually build (a seemingly
correct) libgdal.so with libtool. unfortunately the current incarnation of
the patch is ugly enough to be embarrassing ;).
part of the integration problem is due to the duplication of makefile snippets
that move object file around (thus breaking the libtool build).
i.e. inside frmts/ we have 37 instances of:
../o/%.o:	%.o
	cp $*.o ../o
that need to be changed to something like:
../o/%.o:	%.o
	cp $*.o ../o
	-cp $*.lo ../o
IMHO makefile code duplication is a problem independently of the use of
libtool, so i started looking into the possibility of a substantial makefile
cleanup, that will be a 'must' for trying integrating libtool, but is a good
thing in itself. note that, since all GNUmakefile's already include
GDALmake.opt it is very easy to cut most of the redundancy just moving the
rules inside GDALmake.opt (or by creating a new GNUmakefile.lib included by
GDALmakefile.opt). attached is an example implementation.
if you judge overloading GDALmake.opt with a small library of common rules is
ok, i volunteer to work on that and on some other possible makefile cleanups
that i spotted (BTW: any specific reason for using 'cp $*.o ../o' instead of
just 'cp $< $@'?).
as soon as the build system is libtool-friendly enough, i'll also submit the
libtool patch for review (hopefully it will add the libtool build as a
configure option without affecting the gdal-native build).
cheers,
alessandro
Type: text/x-diff
Desc: not available
Url : http://lists.osgeo.org/pipermail/gdal-dev/attachments/20030710/95ca4aec/frmts-o.bin
