[Gdal-dev] new build strategy for org/orgsf_frmts/
Alessandro Amici alexamici at tiscali.it
Mon Jul 14 18:21:12 EDT 2003
Frank,
i just moved the ogr/ogrsf_frmts/ in cvs to use a build strategy similar to
the frmts/. note that ogrsf_frmts.a now only contains object files from
ogr/ogrsf_frmts/*.
that is, the sdts format is not self contained any more into ogrsf_frmts.a, in
fact a few object files are now only found into gdal.a (they where copied
into ogrsf_frmts.a before).
as far as i can say nothing should change unless someone is linking statically
against ogrsf_frmts.a, but not against gdal.a (?).
if needed i can restore the old behavior.
cheers,
alessandro
