[Gdal-dev] Exception thrown in GDALOpen() function
Ben Discoe
ben at vterrain.org
Mon Jul 28 15:51:13 EDT 2003
> -----Original Message-----
> From: N. Farah
> Sent: Monday, July 28, 2003 1:13 PM
> missing dll:
> "xerces-c_2_1_0.dll". It's seems that binaries has been built
> with the Xerces feature.
Yes, this is easy to get from http://xml.apache.org/xerces-c/
> I went back to rebuild GDAL-1.1.9 on debug mode, i had built
> the lib but the dll and used them in my project, I have an
> an access violation exception with VSIFClose( fp ) in the
> destructor of GDALOpenInfo object .
It also possible that is it is a problem with your application :) but
please do try our binaries first.
-Ben
> In the meantime, may i suggest that rather than build GDAL on Windows,
> you simply use these precompiled binaries:
http://vterrain.org/dist/gdal-119-ntbin.zip (2.3 MB)
It contains the necessary Debug and Release .lib/.dll
-Ben
