[Gdal-dev] build bug
April Shimitz shimitz at usgs.gov
Wed Jun 4 15:46:15 EDT 2003
Thanks Paul, that fixed the problem. I see now that the other print
statements within the configure script escape the second quote as well, so
this one does appear to deviate from the standard.
>> configure[3736]: syntax error at line 3765 : `(' unexpected
>> I looked at the line, but cannot see anything wrong with it; do you see
any
>> or have you had any trouble with the configure script?
>Maybe one of the quotes in the middle needs to be escaped also:
>> print \"-L%s/lib/python%s/config -lpython%s.dll\" % (sys.prefix,
sys.version[:3], sys.version[:3])'`"
>                                                 ^ Change here
>(I also had this problem and this fixed it)
>Paul Kelly
April Shimitz
