[Gdal-dev] build bug
Simon Perkins
s.perkins at lanl.gov
Wed Jun 4 16:22:37 EDT 2003
On Wed, 2003-06-04 at 13:42, Frank Warmerdam wrote:
> >>configure[3736]: syntax error at line 3765 : `(' unexpected
> >>I looked at the line, but cannot see anything wrong with it; do you see any
> >>or have you had any trouble with the configure script?
> > Maybe one of the quotes in the middle needs to be escaped also:
> >>print \"-L%s/lib/python%s/config -lpython%s.dll\" % (sys.prefix, sys.version[:3], sys.version[:3])'`"
> > ^ Change here
> > (I also had this problem and this fixed it)
We had similar problems at one time caused by incompatibilities between
different version of autoconf.
Sy
