[Gdal-dev] SRTM data and GDAL
Markus Neteler
neteler at itc.it
Fri Mar 7 04:43:27 EST 2003
Dear GDAL users,
since yesterday a SRTM shuttle elevation data are available
for Northern America at around 90m resolution (0:00:03 deg):
http://www.jpl.nasa.gov/srtm/cbanddataproducts.html
ftp://srtm.usgs.gov/pub/data/srtm/North_America/3arcsec/
The trick to use them with GDAL is as follows:
- unpack the .zip file
- mv NXXWYYY.hgt NXXWYYY.bil
- create a .hdr file (ARC/INFO style) from the file name:
Example for N18W077.bil
BYTEORDER M
LAYOUT BIL
NROWS 1201
NCOLS 1201
NBANDS 1
NBITS 16
BANDROWBYTES 2402
TOTALROWBYTES 2402
BANDGAPBYTES 0
NODATA -32768
ULXMAP -76.9995833333 <- WYYY - 0.0004166667
ULYMAP 19.00041666666667 <- NXX + 1.0004166667
XDIM 0.000833333333333
YDIM 0.000833333333333
Then gdalinfo then accepts the file and reports:
gdalinfo -mm N18W077.bil
Driver: EHdr/ESRI .hdr Labelled
Size is 1201, 1201
Coordinate System is '
Origin = (-77.000000,19.000833)
Pixel Size = (0.000833,-0.000833)
Corner Coordinates:
Upper Left ( -77.0000000, 19.0008333)
Lower Left ( -77.0000000, 18.0000000)
Upper Right ( -75.9991667, 19.0008333)
Lower Right ( -75.9991667, 18.0000000)
Center ( -76.4995833, 18.5004167)
Band 1 Block=1201x1 Type=Int16, ColorInterp=Undefined
Computed Min/Max=-10.000,2024.000
NoData Value=-32768
Maybe the GDAL authors could add a simple HGT driver which
automagically constructs the .hdr file internally on the fly.
Anyway, with above method you can easily import/convert
the data (also tested with GRASS).
Cheers
Markus
Markus Neteler
ITC-irst, Istituto per la Ricerca Scientifica e Tecnologica
Project on Predictive Models for the Environment
Via Sommarive, 18 - 38050 Povo (Trento), Italy
tel +39 0461 314 520 (fax -591) http://mpa.itc.it
