[Gdal-dev] saving GeoTiff
Ayman Kamal
kamal_jo at yahoo.com
Tue Mar 11 07:43:08 EST 2003
I don't need a program, I need some sort of code or
dll to use in my own code, I am not an end user.
--- Roger James <rogerjames99 at btinternet.com> wrote:
> Ayman,
> I you convert the file to to an ordinary tiff, you
> can use my georef
> program to give it co-ordinate information. You will
> need the
> co-ordinates of three ground control points visible
> in the upper left,
> upper right, and lower left quadrants of the image.
> You can find georef
> at www.beardandsandals.co.uk.
> Roger
> -----Original Message-----
> From: gdal-dev-admin at remotesensing.org
> [mailto:gdal-dev-admin at remotesensing.org] On Behalf
> Of Ayman Kamal
> Sent: 11 March 2003 08:01
> To: gdal-dev at remotesensing.org
> Subject: [Gdal-dev] saving GeoTiff
> I want to be able to convert a "bmp" file to a
> "GeoTiff" file.
> I used gdal_translate to do this, but the resulting
> file didn't of course contain georeferencing data.
> Now:
> 1. Is it possible (if I find the goereferencing
> data)
> to give them to GDAL SDK so that GDAL can generate a
> GeoTiff file with georeferencing data embeded
> inside?
> if (1.)
> 2. What data do I need to supply to GDAL to
> accomplish this?
> 3. What functions to use in GDAL to save such
> data
> in thre resulting GeoTiff file?
> else
> 4. Can you help me in any means to accomoplish
> this?
> __________________________________________________
> Do you Yahoo!?
> Yahoo! Web Hosting - establish your business online
> http://webhosting.yahoo.com
> Gdal-dev mailing list
> Gdal-dev at remotesensing.org
> http://remotesensing.org/mailman/listinfo/gdal-dev
Do you Yahoo!?
