[Gdal-dev] line to polygon with ogr2ogr?
Frank Warmerdam
warmerdam at pobox.com
Tue Mar 25 11:42:18 EST 2003
Vincent Schut wrote:
> Just to be really sure I thought I'd ask...:
> Is it possible to convert a line (multiline) shapefile to a polygon shapefile
> using ogr2ogr?
> I have a shapefile (I did not create myself, of course...) which was for some
> (none) reason saved as line, but should be polygon. All lines are closed as
> far as I could see, but the type is just wrong and I can't add it to my main
> polygon table for this theme in postgis. Can I change this with ogr2ogr, or
> do I need some other trick?
Vincent,
This can't be fixed with ogr2ogr. It could, in theory, be fixed with a
python script as long as the dataset isn't too extraordinarily large, or
it could be fixed in a C/C++ program.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
