[Gdal-dev] GDAL, JasPer, JPEG2000 memory management plans?
Brent Fraser bfraser at geoanalytic.com
Wed May 7 15:17:26 EDT 2003
MessageCarl,
   I thought that using some more JasPer parameters might improve my situation, but JasPer's doc didn't go into very much detail on parameters (and I wasn't looking forward to reading the JPEG2000 spec at this point in my investigation).
   Can you give me an example of the gdal_translate command line you use with tiling parameters?
Thanks!
Brent Fraser
  ----- Original Message -----
  To: gdal-dev at remotesensing.org
  Sent: Wednesday, May 07, 2003 12:42 PM
  Subject: RE: [Gdal-dev] GDAL, JasPer, JPEG2000 memory management plans?
  I have been having problems encoding 13001x13001 JEPG2000 images on a
  Linux 2.4.20 machine and a Solaris 2.7 machine using gdal_translate and jasper
  on each machine unless I use tiling, encoding  dies inside jasper at
      jpc_t1enc.c on line 349   (  assert(0)  )
  When I do use tiling the result is ok.
  RE memory management:
  what about an implementation of a "Row-based wavelet transform" as described in
  ITU-T Rec T.800 (2000 FCDV1.0) page 163. Downloadable from http://www.jpeg.org/public/fcd15444-1.pdf
  of course that is really a jasper issue not a gdal one, and it may already be in the jasper lib.
  Carl Anderson
  GIS Manager
  Fulton County E&CD
  404.730.8026
  carl.anderson at co.fulton.ga.us
    -----Original Message-----
    From: Brent Fraser [mailto:bfraser at geoanalytic.com]
    Sent: Wednesday, May 07, 2003 2:11 PM
    To: gdal-dev
    Subject: [Gdal-dev] GDAL, JasPer, JPEG2000 memory management plans?
    Frank, Andrey (and others),
        I've done some experimenting with GDAL's JPEG2000 capabilities on Windows 2000.
        While I got good results with a small (2mb, 929 x 986 pixels, RGB) and medium (20 mb, 2961 x 2270, RGB) size files, I noticed memory management  problems with large (100 mb, 4482 x x9011, RGB) and huge (1 gb, 18595 x 19729, RGB) files.
        During the translation of the large 100 mb file, 1.4 gb of ram was eventually allocated (90% of it by the JasPer code), but it did successfully finish after about 20 min.
        With the huge 1 gb tif file, GDAL_translate appears to allocate about 1 gb during the reading of the original tif file and attemps to allocate another 1 gb (in the Jasper code) just before starting to compress.  The second memory allocation fails on my computer (Windows 2000) even though I've got my virtual memory set to the maximum of 4 gb.
        Are there any enhancements that could be done to GDAL to reduce the amount of memory used?  I realize that wavelet compression (or at least the implementation in JasPer) may not lend itself to efficient memory use, and that GDAL's integration of JasPer is fairly new, but I thought I would get my request in early!
    FYI, here's an example of my command line for the translation:
        gdal_translate -of JPEG2000 -co "FORMAT=JP2" -co "rate=0.05" small.tif small.jp2
    Thanks and keep up the good work!
    Brent Fraser
    GeoAnalytic Inc.
    Tel:(403) 213-2700
    www.geoanalytic.com
    The contents of this message have been scanned for viruses by
    the TruSecure ShadowMail Service, and no viruses were found.
  * This message has been processed by TruSecure's ShadowMail service
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20030507/dd35cdc4/attachment.html
