[Gdal-dev] gml geometry information
Roger James
rogerjames99 at btinternet.com
Wed May 14 16:44:08 EDT 2003
Frank,
I have just noticed that the ogr gml driver reports geometry at the
feature level but not at the layer level. Is this intended? Also the
spatial ref is not being picked up. Sorry I have not had chance to look
closely at these.
C:\mapdata\Vector Data\2085\sd>ogrinfo -al swh.gml|more
ERROR 1: Read failed on swh.gfs.
Had to open data source read-only.
INFO: Open of `swh.gml'
using driver `GML' successful.
Layer name: osgb:TopographicPoint
Geometry: Unknown (any)
Feature Count: 6
Extent: (347195.900000, 465403.500000) - (347443.100000, 465789.200000)
Layer SRS WKT:
(unknown)
osgb:featureCode: String (0.0)
osgb:version: String (0.0)
osgb:versionDate: String (0.0)
osgb:theme: String (0.0)
osgb:accuracyOfPosition: String (0.0)
osgb:descriptiveGroup: String (0.0)
osgb:descriptiveTerm: String (0.0)
osgb:physicalLevel: String (0.0)
osgb:make: String (0.0)
OGRFeature(osgb:TopographicPoint):0
osgb:featureCode (String) = 10197
osgb:version (String) = 1
osgb:versionDate (String) = 2001-11-09
osgb:theme (String) = Terrain And Height
osgb:accuracyOfPosition (String) = Unknown
osgb:descriptiveGroup (String) = Terrain And Height
osgb:descriptiveTerm (String) = Spot Height
osgb:physicalLevel (String) = 50
osgb:make (String) = (null)
POINT (347297.300 465584.000)
* More --
By the way the ERROR is the one I mentioned a few days ago on the list
caused by CR/LF processing.
Roger
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20030514/d14daf22/attachment.html
