[Gdal-dev] CreateCopy()
Simon Perkins s.perkins at lanl.gov
Fri May 23 16:44:33 EDT 2003
Just noticed that the default CreateCopy() routine doesn't copy metadata
from the source dataset to the target one. Although it does copy
metadata from each _band_ in the source dataset to each band in the
target (not sure what this is for).
I've CVS committed a one line fix to gdaldriver.cpp. Let me know if
there are any problems...
Cheers,
Sy
