[Gdal-dev] OGR Error on State Plane transform
Garvan Keeley
garvank at optech.on.ca
Fri May 30 14:09:02 EDT 2003
Hi Frank,
the version of GDAL is from CVS, the last update was March 24. I'll pull the
latest and rebuild.
I am using Windows, Visual C++.
The code:
OGRSpatialReference source;
OGRSpatialReference destination;
OGRCoordinateTransformation* transform;
source.SetWellKnownGeogCS("NAD83");
destination.SetWellKnownGeogCS("NAD83");
destination.SetStatePlane(101, true);
transform = OGRCreateCoordinateTransformation(&source,
&destination);
if (transform != NULL) {
double x = -87.0, y = 30.5;
OGRErr err = transform->Transform(1, &x, &y, NULL);
if (err != OGRERR_NONE)
TRACE("%s\n", CPLGetLastErrorMsg());
TRACE("Transform Result: %f %f \n", x, y);
delete transform;
> Garvan,
> What version of GDAL are you using? Note that GDAL now
> (since the EPSG 6.2.2 upgrade a couple of months ago) uses
> more csv files than those distributed with libgeotiff, so it
> is necessary for GDAL to find the files in the gdal/data
> directory. These include a file listing state plane zones
> and "concatenated" information about files projected and
> geographic coordinate systems.
> However, the message you are getting about horiz_cs.csv is
> odd. The horiz_cs.csv doesn't exist anymore. It seems
> likely you are either using old software, or there is a part
> of GDAL (or libgeotiff) that hasn't been updated to the new
> scheme properly. To track that down I need details of the
> version of GDAL, command and projections involved.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam,
> warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | Geospatial
> Programmer for Rent
> Gdal-dev mailing list
> Gdal-dev at remotesensing.org
> http://remotesensing.org/mailman/listinfo/gdal-> dev
