[Gdal-dev] Build GDAL on windows using minGW
Norman Vine nhv at cape.com
Mon Nov 10 13:39:08 EST 2003
Gagan Tandon writes:
> I had received suggestions from Norman and Alessandro sometime back to use
> either minGW or cygwin for building GDAL on windows without installing MS VC++
> (sorry for a delayed response, as I was up to something else..:-)..).
> I have installed minGW/minSYS on my windows machine. But the usual build instructions
> given on remotesensing.org/GDAL website for windows(or unix) do not work on the minSYS
> interface. Obviously I am doing something wrong here. Does anybody has links/clues on
> how to build GDAL using minGW/minSYS..?
Have installed the MSYS development tools
i.e do you have automake and friends installed
> I plan to use python 2.3 (for windows) to interact with GDAL.
I haven't tried building the python extension with MingW
FWIW - AFAIK precompiled  GDAL libraries to include the Python
extensions are included in the OpenEV Windows download
http://openev.sf.net
HTH
Norman
