[Gdal-dev] error and fix for s57 breakage
Frank Warmerdam
warmerdam at pobox.com
Fri Nov 14 08:08:42 EST 2003
Vincent Schut wrote:
> Frank and others,
> due to an error in gdal/ogr/ogrsf_frmts/s57/GNUMakefile gdal-cvs won't
> compile if ogr is enabled. The solution is to add 's57featuredefns.o'
> to the 'OBJ =' line in the GNUMakefile in the s57 directory (and
> probably similar addition to the Makefile?).
Vincent,
Sorry, I have committed that change.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
