[Gdal-dev] error and fix for s57 breakage
Vincent Schut
schut at sarvision.com
Fri Nov 14 08:19:45 EST 2003
On 2003.11.14 14:08, Frank Warmerdam wrote:
> Vincent Schut wrote:
>> Frank and others,
>> due to an error in gdal/ogr/ogrsf_frmts/s57/GNUMakefile gdal-cvs
>> won't compile if ogr is enabled. The solution is to add
>> 's57featuredefns.o' to the 'OBJ =' line in the GNUMakefile in the
>> s57 directory (and probably similar addition to the Makefile?).
> Vincent,
> Sorry, I have committed that change.
> Best regards,
Frank,
no matters, it was relatively easy to track down. Glad to help this way :)
Vincent
> I set the clouds in motion - turn up | Frank Warmerdam,
> warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | Geospatial Programmer for
> Rent
> Gdal-dev mailing list
> Gdal-dev at remotesensing.org
> http://remotesensing.org/mailman/listinfo/gdal-dev
