[Gdal-dev] Bug in ogr mitab driver
Roger James roger at beardandsandals.co.uk
Fri Nov 21 14:56:57 EST 2003
Frank,
There is a bug in mitab_miffile.cpp.
When reading column names if the start of the column name matches any of
the predefined mapinfo header names such as Version, then the column
description is interpreted as a occurrence of that header field rather
than as a user defined column description.
My apologies if this has already been reported.
Roger
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20031121/c94c8f66/attachment.html
