[Gdal-dev] Bug in ogr mitab driver
Frank Warmerdam
warmerdam at pobox.com
Fri Nov 21 15:53:20 EST 2003
Roger James wrote:
> Frank,
> There is a bug in mitab_miffile.cpp.
> When reading column names if the start of the column name matches any of
> the predefined mapinfo header names such as Version, then the column
> description is interpreted as a occurrence of that header field rather
> than as a user defined column description.
> My apologies if this has already been reported.
Roger,
Could you submit this as a bug into the MITAB bugzilla at mitab.maptools.org?
Thanks,
and watch the world go round - Rush | Geospatial Programmer for Rent
