[Gdal-dev] ECW support
Jeff Fearn
jfearn at webmap.com.au
Thu Oct 2 18:47:19 EDT 2003
Thanks Frank :)
Jeff Fearn <jfearn at webmap.com.au>
Technical Officer
Webmap Pty Ltd
http://www.webmap.com.au
Phone: +61 7 3841 2911
Fax: +61 7 3341 8005
-----Original Message-----
[mailto:gdal-dev-admin at remotesensing.org] On Behalf Of Frank Warmerdam
Sent: Thursday, 2 October 2003 11:22 PM
To: gdal-dev at remotesensing.org
Subject: Re: [Gdal-dev] ECW support
Jeff Fearn wrote:
> Is there a configuration option I can set to use ECWs with the windows
> binary install of OpenEV 1.60, or do I need to compile this support in?
> As I don't have a compiler on Windows and ECWs aren't supported on Linux
the
> second option is bad for me :{
> hmmm while I'm asking, is it the same for JPEG2000 support?
> Technical Officer
> Webmap Pty Ltd
> +61 7 3841 2911
Jeff,
I don't *think* that OpenEV 1.60 was built with ECW support. The OpenEV_FW
1.6.2 build at this URL should include ECW support:
http://gdal.maptools.org/dl/openev/OpenEV_FW_162.zip
The same applies for JPEG2000 support. Not in the 1.6.0 build, but it is in
the OpenEV_FW 1.6.2 build.
Best regards,
I set the clouds in motion - turn up | Frank Warmerdam,
warmerdam at pobox.com
and watch the world go round - Rush | Geospatial Programmer for Rent
Gdal-dev mailing list
Gdal-dev at remotesensing.org
http://remotesensing.org/mailman/listinfo/gdal-dev
