[Gdal-dev] ECW support
Frank Warmerdam
warmerdam at pobox.com
Thu Oct 2 09:22:04 EDT 2003
Jeff Fearn wrote:
> Is there a configuration option I can set to use ECWs with the windows
> binary install of OpenEV 1.60, or do I need to compile this support in?
> As I don't have a compiler on Windows and ECWs aren't supported on Linux the
> second option is bad for me :{
> hmmm while I'm asking, is it the same for JPEG2000 support?
> Jeff Fearn <jfearn at webmap.com.au>
> Technical Officer
> Webmap Pty Ltd
> http://www.webmap.com.au
> +61 7 3841 2911
Jeff,
I don't *think* that OpenEV 1.60 was built with ECW support. The OpenEV_FW
1.6.2 build at this URL should include ECW support:
http://gdal.maptools.org/dl/openev/OpenEV_FW_162.zip
The same applies for JPEG2000 support. Not in the 1.6.0 build, but it is in
the OpenEV_FW 1.6.2 build.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
