[Gdal-dev] ECW support
Gillian Walter
gillian.walter at atlantis-scientific.com
Thu Oct 2 09:03:03 EDT 2003
OpenEVs built at Atlantis (including OpenEV 1.60) include GDAL's that
only have support for default formats compiled in- if extra libraries
are required to support a format, they are not built in. ECW is not
included in this list, and there is no option to turn it on. JPEG2000
is also not built into the Atlantis versions. The OpenEV_FW series
(built by Frank) include the most format support of the OpenEV builds
(though I don't know if ECW is in any of them). They can be downloaded at:
ftp://ftp.remotesensing.org/pub/gdal/openev/
You might want to try OpenEV_FW_162 for a start.
- Gillian
Jeff Fearn wrote:
>Is there a configuration option I can set to use ECWs with the windows
>binary install of OpenEV 1.60, or do I need to compile this support in?
>As I don't have a compiler on Windows and ECWs aren't supported on Linux the
>second option is bad for me :{
>hmmm while I'm asking, is it the same for JPEG2000 support?
>Jeff Fearn <jfearn at webmap.com.au>
>Technical Officer
>Webmap Pty Ltd
>http://www.webmap.com.au
>+61 7 3841 2911
>_______________________________________________
>Gdal-dev mailing list
>Gdal-dev at remotesensing.org
>http://remotesensing.org/mailman/listinfo/gdal-dev
