[Gdal-dev] Sinusoidal projection for MODIS images with OGR
Markus Neteler
neteler at itc.it
Wed Oct 15 12:13:10 EDT 2003
On Tue, Oct 14, 2003 at 01:41:31PM -0400, Ben Discoe wrote:
> Well, if the images are in a normal sinusoidal (SIN), then we don't need the
> MODIS reproject tool at all, we can just use GDAL :-)
Mhhh, for me it doesn't work (yesterday's CVS version). Trying on
"MODIS/Terra Land Surface Temperature/Emissivity Daily L3 Global 1km SIN Grid":
gdalinfo MOD11A1.A2000055.h18v04.004.2002355023354.hdf
Driver: HDF4/Hierarchical Data Format Release 4
Size is 512, 512
Coordinate System is '
Metadata:
HDFEOSVersion=HDFEOS_V2.4
LOCALGRANULEID=MOD11A1.A2000055.h18v04.004.2002355023354.hdf
PRODUCTIONDATETIME=2002-12-21T02:33:54.000Z
DAYNIGHTFLAG=Both
REPROCESSINGACTUAL=reprocessed
LOCALVERSIONID=SCF V4.1.3A
REPROCESSINGPLANNED=further update is anticipated
SCIENCEQUALITYFLAG=Not Investigated
AUTOMATICQUALITYFLAGEXPLANATION=Passed if algorithm ran within bounds of execution constraints. Suspect if bounds of execution constraints violated. Failed if PGE failed.
AUTOMATICQUALITYFLAG=Passed
SCIENCEQUALITYFLAGEXPLANATION=See http://landdb1.nascom.nasa.gov/QA_WWW/release.cgi for the Science QA status of this product.
QAPERCENTMISSINGDATA=0
QAPERCENTOUTOFBOUNDSDATA=0
QAPERCENTCLOUDCOVER=61
QAPERCENTINTERPOLATEDDATA=0
PARAMETERNAME=MOD 1KM L3 LST
VERSIONID=4
SHORTNAME=MOD11A1
INPUTPOINTER=MOD03.A2000055.1010.004.2002296011149.hdf,MOD021KM.A2000055.1010.004.2002296173139.hdf,MOD35_L2.A2000055.1010.004.2002297061857.hdf,MOD10_L2.A2000055.1010.004.2002354210009.hdf,MOD07_L2.A2000055.1010.004.2002297062000.hdf,MOD03.A2000055.1145.004.2002296011823.hdf,MOD021KM.A2000055.1145.004.2002296023327.hdf,MOD35_L2.A2000055.1145.004.2002296060357.hdf,MOD10_L2.A2000055.1145.004.2002354210217.hdf,MOD07_L2.A2000055.1145.004.2002296060509.hdf,MOD03.A2000055.1150.004.2002296012012.hdf,MOD021KM.A2000055.1150.004.2002296023356.hdf,MOD35_L2.A2000055.1150.004.2002296060336.hdf,MOD10_L2.A2000055.1150.004.2002354210217.hdf,MOD07_L2.A2000055.1150.004.2002296060449.hdf,MOD03.A2000055.2115.004.2002296073024.hdf,MOD021KM.A2000055.2115.004.2002296082726.hdf,MOD35_L2.A2000055.2115.004.2002296134515.hdf,MOD07_L2.A2000055.2115.004.2002296134700.hdf,MOD03.A2000055.2120.004.2002296073106.hdf,MOD021KM.A2000055.2120.004.2002296101156.hdf,MOD35_L2.A2000055.2120.004.2002296134111.hdf,MOD07_L2.A2000055.2120.004.2002296134234.hdf,MOD03.A2000055.2255.004.2002296095939.hdf,MOD021KM.A2000055.2255.004.2002296145019.hdf,MOD35_L2.A2000055.2255.004.2002296165000.hdf,MOD07_L2.A2000055.2255.004.2002296165152.hdf
GRINGPOINTLONGITUDE=0.000000, 15.544281, 13.044787, 0.000000
GRINGPOINTLATITUDE=49.995833, 49.995833, 40.004167, 40.004167
GRINGPOINTSEQUENCENO=1, 2, 3, 4
EXCLUSIONGRINGFLAG=N
RANGEENDINGDATE=2000-02-24
RANGEENDINGTIME=22:59:36.085400
RANGEBEGINNINGDATE=2000-02-24
RANGEBEGINNINGTIME=10:10:38.975336
PGEVERSION=4.1.4
ASSOCIATEDSENSORSHORTNAME=MODIS
ASSOCIATEDPLATFORMSHORTNAME=Terra
ASSOCIATEDINSTRUMENTSHORTNAME=MODIS
QAPERCENTGOODQUALITY=12
QAPERCENTOTHERQUALITY=0
QAPERCENTNOTPRODUCEDCLOUD=61
QAPERCENTNOTPRODUCEDOTHER=27
N_GRAN_POINTERS=27
HORIZONTALTILENUMBER=18
VERTICALTILENUMBER=04
TileID=51018004
QAFRACTIONGOODQUALITY=0.1232632
QAFRACTIONOTHERQUALITY=0.0000000
QAFRACTIONNOTPRODUCEDCLOUD=0.6113181
QAFRACTIONNOTPRODUCEDOTHER=0.2654187
ALGORITHMPACKAGEACCEPTANCEDATE=1997-11-01
ALGORITHMPACKAGEMATURITYCODE=pre-launch
ALGORITHMPACKAGENAME=MOD_PR11A_V3
ALGORITHMPACKAGEVERSION=Version 2
LONGNAME=MODIS/Terra Land Surface Temperature/Emissivity Daily L3 Global 1km SIN Grid
INSTRUMENTNAME=Moderate-Resolution Imaging SpectroRadiometer
INPUTTILEPOINTER=MOD12Q1.A2000289.h18v04.003.2002170222129.hdf
INPUTTILEPOINTER=MOD11A1.1.A2000055.h18v04.hdf
INPUTTILEPOINTER=MOD11B1.1.A2000055.h18v04.hdf
INPUTTILEPOINTER=MOD11UPD.A2-1.1.update_for_lst.h18v04.hdf
INPUTGRANULEPOINTER=MOD03.A2000055.1010.004.2002296011149.hdf
INPUTGRANULEPOINTER=MOD021KM.A2000055.1010.004.2002296173139.hdf
INPUTGRANULEPOINTER=MOD35_L2.A2000055.1010.004.2002297061857.hdf
INPUTGRANULEPOINTER=MOD10_L2.A2000055.1010.004.2002354210009.hdf
INPUTGRANULEPOINTER=MOD07_L2.A2000055.1010.004.2002297062000.hdf
INPUTGRANULEPOINTER=MOD03.A2000055.1145.004.2002296011823.hdf
INPUTGRANULEPOINTER=MOD021KM.A2000055.1145.004.2002296023327.hdf
INPUTGRANULEPOINTER=MOD35_L2.A2000055.1145.004.2002296060357.hdf
INPUTGRANULEPOINTER=MOD10_L2.A2000055.1145.004.2002354210217.hdf
INPUTGRANULEPOINTER=MOD07_L2.A2000055.1145.004.2002296060509.hdf
INPUTGRANULEPOINTER=MOD03.A2000055.1150.004.2002296012012.hdf
INPUTGRANULEPOINTER=MOD021KM.A2000055.1150.004.2002296023356.hdf
INPUTGRANULEPOINTER=MOD35_L2.A2000055.1150.004.2002296060336.hdf
INPUTGRANULEPOINTER=MOD10_L2.A2000055.1150.004.2002354210217.hdf
INPUTGRANULEPOINTER=MOD07_L2.A2000055.1150.004.2002296060449.hdf
INPUTGRANULEPOINTER=MOD03.A2000055.2115.004.2002296073024.hdf
INPUTGRANULEPOINTER=MOD021KM.A2000055.2115.004.2002296082726.hdf
INPUTGRANULEPOINTER=MOD35_L2.A2000055.2115.004.2002296134515.hdf
INPUTGRANULEPOINTER=MOD07_L2.A2000055.2115.004.2002296134700.hdf
INPUTGRANULEPOINTER=MOD03.A2000055.2120.004.2002296073106.hdf
INPUTGRANULEPOINTER=MOD021KM.A2000055.2120.004.2002296101156.hdf
INPUTGRANULEPOINTER=MOD35_L2.A2000055.2120.004.2002296134111.hdf
INPUTGRANULEPOINTER=MOD07_L2.A2000055.2120.004.2002296134234.hdf
INPUTGRANULEPOINTER=MOD03.A2000055.2255.004.2002296095939.hdf
INPUTGRANULEPOINTER=MOD021KM.A2000055.2255.004.2002296145019.hdf
INPUTGRANULEPOINTER=MOD35_L2.A2000055.2255.004.2002296165000.hdf
INPUTGRANULEPOINTER=MOD07_L2.A2000055.2255.004.2002296165152.hdf
LOCALINPUTGRANULEID=1010,1145,1150,2115,2120,2255
LOOKUPTABLETYPE=Land-cover based band emissivity database
LOOKUPTABLEPOINTER=band_emis.h
LOOKUPTABLETYPE=the generalized split-window LST coefficients
LOOKUPTABLEPOINTER=lst_coef.h
PROCESSINGCENTER=GSFC
PROCESSINGDATETIME=2002-12-21T02:33:54.000Z
NORTHBOUNDINGCOORDINATE=49.995833
SOUTHBOUNDINGCOORDINATE=40.004167
EASTBOUNDINGCOORDINATE=15.544281
WESTBOUNDINGCOORDINATE=0.000000
SPSOPARAMETERS=2484 and 3323
PROCESSINGENVIRONMENT=IRIX64 mtvs2 6.5 07121149 IP35
DESCRREVISION=4.0
Subdatasets:
SUBDATASET_1_NAME=HDF4_SDS:UNKNOWN:"MOD11A1.A2000055.h18v04.004.2002355023354.hdf":0
SUBDATASET_1_DESC=[1200x1200] LST_Day_1km (16-bit unsigned integer)
SUBDATASET_2_NAME=HDF4_SDS:UNKNOWN:"MOD11A1.A2000055.h18v04.004.2002355023354.hdf":1
SUBDATASET_2_DESC=[1200x1200] QC_Day (8-bit unsigned integer)
SUBDATASET_3_NAME=HDF4_SDS:UNKNOWN:"MOD11A1.A2000055.h18v04.004.2002355023354.hdf":2
SUBDATASET_3_DESC=[1200x1200] Day_view_time (8-bit unsigned integer)
SUBDATASET_4_NAME=HDF4_SDS:UNKNOWN:"MOD11A1.A2000055.h18v04.004.2002355023354.hdf":3
SUBDATASET_4_DESC=[1200x1200] Day_view_angl (8-bit unsigned integer)
SUBDATASET_5_NAME=HDF4_SDS:UNKNOWN:"MOD11A1.A2000055.h18v04.004.2002355023354.hdf":4
SUBDATASET_5_DESC=[1200x1200] LST_Night_1km (16-bit unsigned integer)
SUBDATASET_6_NAME=HDF4_SDS:UNKNOWN:"MOD11A1.A2000055.h18v04.004.2002355023354.hdf":5
SUBDATASET_6_DESC=[1200x1200] QC_Night (8-bit unsigned integer)
SUBDATASET_7_NAME=HDF4_SDS:UNKNOWN:"MOD11A1.A2000055.h18v04.004.2002355023354.hdf":6
SUBDATASET_7_DESC=[1200x1200] Night_view_time (8-bit unsigned integer)
SUBDATASET_8_NAME=HDF4_SDS:UNKNOWN:"MOD11A1.A2000055.h18v04.004.2002355023354.hdf":7
SUBDATASET_8_DESC=[1200x1200] Night_view_angl (8-bit unsigned integer)
SUBDATASET_9_NAME=HDF4_SDS:UNKNOWN:"MOD11A1.A2000055.h18v04.004.2002355023354.hdf":8
SUBDATASET_9_DESC=[1200x1200] Emis_31 (8-bit unsigned integer)
SUBDATASET_10_NAME=HDF4_SDS:UNKNOWN:"MOD11A1.A2000055.h18v04.004.2002355023354.hdf":9
SUBDATASET_10_DESC=[1200x1200] Emis_32 (8-bit unsigned integer)
SUBDATASET_11_NAME=HDF4_SDS:UNKNOWN:"MOD11A1.A2000055.h18v04.004.2002355023354.hdf":10
SUBDATASET_11_DESC=[1200x1200] Clear_day_cov (16-bit unsigned integer)
SUBDATASET_12_NAME=HDF4_SDS:UNKNOWN:"MOD11A1.A2000055.h18v04.004.2002355023354.hdf":11
SUBDATASET_12_DESC=[1200x1200] Clear_night_cov (16-bit unsigned integer)
Corner Coordinates:
Upper Left ( 0.0, 0.0)
Lower Left ( 0.0, 512.0)
Upper Right ( 512.0, 0.0)
Lower Right ( 512.0, 512.0)
Center ( 256.0, 256.0)
Do you have a suggestion for me?
Thanks,
Markus
