[Gdal-dev] gdalwarp resampling
Ray Joslyn
RJoslyn at etg-sadi.com
Tue Oct 28 15:46:32 EST 2003
Frank,
Actually I was using the -tr option to set the output pixel size larger
than my source. The resample options do show up in the usage message so
I am using a version that supports the resampling. However, as before
there doesn't seem to be any difference in the output with the different
resampling options.
Ray
-----Original Message-----
From: Frank Warmerdam [mailto:warmerdam at pobox.com]
Sent: Tuesday, October 28, 2003 2:26 PM
To: gdal-dev at remotesensing.org
Subject: Re: [Gdal-dev] gdalwarp resampling
Ray Joslyn wrote:
> Frank,
> No, I'm not actually warping the image. What I was after was a way of
> resampling the pixel size up while taking advantage of the
interpolation
> methods.
> Ray
Ray,
OK, well it should work for this case. I guess you are using the -ts
switch
to set a larger size for the output image?
Best regards,
I set the clouds in motion - turn up | Frank Warmerdam,
and watch the world go round - Rush | Geospatial Programmer for Rent
Gdal-dev mailing list
Gdal-dev at remotesensing.org
http://remotesensing.org/mailman/listinfo/gdal-dev
