[Gdal-dev] gdalwarp resampling
Tue Oct 28 15:26:08 EST 2003
Ray Joslyn wrote:
> Frank,
> No, I'm not actually warping the image.  What I was after was a way of
> resampling the pixel size up while taking advantage of the interpolation
> methods.
> Ray
Ray,
OK, well it should work for this case.  I guess you are using the -ts switch
to set a larger size for the output image?
Best regards,
