I: [Gdal-dev] Patching after configure
Sean Fulton
fulton at cmu.edu
Wed Oct 29 10:12:43 EST 2003
Alessandro,
Ooops. I meant to send this to the DarwinPorts list. But it's good to
know the next version won't require a patch. Is there an ETA for the
next version? I might just wait.
Thanks.
Sean
p.s. FYI, DarwinPorts is the Apple version of the BSD ports system.
It's similar to Fink.
On Wednesday, October 29, 2003, at 04:44 AM, Amici Alessandro wrote:
> just in case you were not subscibed to gdal-dev.
> -----Messaggio originale-----
> Da: Amici Alessandro
> Inviato: mercoledì 29 ottobre 2003 10.42
> A: 'gdal-dev at remotesensing.org'
> Oggetto: R: [Gdal-dev] Patching after configure
> Sean,
>> Am I correct in assuming the patches in 'patchfiles' are applied
>> before
>> configure is run? Is there a way to patch after configure is run?
> ? never heard about a 'patchfiles', so i cannot help here...
>> I'm trying to do a portfile for GDAL
>> (http://www.remotesensing.org/gdal/). The info I can find for building
>> it on OS X requires modifying the GDALmake.opt file which is generated
>> from the configure script.
>> The patch changes "LD_SHARED = gcc -dynamiclib"
>> to "LD_SHARED = g++ -dynamiclib"
>> I don't actually know all that much about the build process so if
>> anyone has a suggestion of another fix, I'd love to hear it.
> ... however, the current cvs snapshot should support OSX out-of-the-box
> (except the python module possibly) and the next stable release should
> not
> be that far in time by now.
> if you absolutely need to use gdal 1.1.9 something similar to:
> http://www.remotesensing.org/cgi-bin/cvsweb.cgi/osrs/gdal/
> aclocal.m4.diff?r1
> =1.38&r2=1.39&f=u
> can be applied before configure, but than you need to run autoconf as
> well.
> BTW, i did most of the porting work that is into gdal cvs now, if you
> encounter any bug or have additional feature requests feel free to
> send it to the list, and i'll see what i can do. MacOSX is definetly a
> porting target taht i'd like to support.
> cheers
> alessadnro
