Hi, maybe a known problem, related to current CVS version: make install does not copy any more libgdal.1.1.so to the target directory (although it appears in the install ... command). libgdal.a *is* copied. I have tested under Mandrake 9.1 and Redhat 7.3, the machines are unchanged. Some days/weeks ago it was working well. Best regards Markus
