RES: RES: [Gdal-dev] Compiling GDAL
Gabriel Moricz gabriel at autofax.com.br
Wed Apr 14 11:16:23 EDT 2004
I did not get it...
Well...
I pretend to use mapserver with gd, proj, gdal, ogr, wmsclient, postgis,
wms, wfsclient, httpd..
Well...Do u think that I will have problems if I compile GDAL without gif???
Sry..I am a begginer with this service...
Thanks..
Gabriel Moricz
-----Mensagem original-----
De: gdal-dev-admin at remotesensing.org
[mailto:gdal-dev-admin at remotesensing.org]Em nome de Frank Warmerdam
Enviada em: quarta-feira, 14 de abril de 2004 12:05
Para: gdal-dev at remotesensing.org
Assunto: Re: RES: [Gdal-dev] Compiling GDAL
Gabriel Moricz wrote:
> Thanks Frank...
> Well....If I install it without Gif, what will happen later when I install
> MapServer...
> Does MapServer requires gdal with GIF???
Gabriel,
MapServer generally uses the GIF support that comes with GD.  However, lack
of GDAL gif support might gum up use of remote WMS layers delivered as GIF
which, I think, go through GDAL.
Best regards,
I set the clouds in motion - turn up   | Frank Warmerdam,
warmerdam at pobox.com
Gdal-dev mailing list
Gdal-dev at remotesensing.org
http://remotesensing.org/mailman/listinfo/gdal-dev
