RES: RES: [Gdal-dev] Compiling GDAL
Wed Apr 14 11:25:29 EDT 2004
Gabriel Moricz wrote:
> I did not get it...
> Well...
> I pretend to use mapserver with gd, proj, gdal, ogr, wmsclient, postgis,
> wms, wfsclient, httpd..
> Well...Do u think that I will have problems if I compile GDAL without gif???
> Sry..I am a begginer with this service...
Gabriel,
If you are not using other WMS servers as input to your MapServer you should
not have any problems using a GDAL built without gif support.
Best regards,
