[Gdal-dev] GDAL 1.1.9 in VC.NET 2003
David Schulze David.Schulze at delorme.com
Thu Apr 15 15:38:09 EDT 2004
Has anyone built GDAL 1.1.9 in VC.NET 2003?
I'm asking to see if there are any know issues with doing this, or some
reason to move up to GDAL 1.2.0.
Is the version of Jasper I use with GDAL dependent on the GDAL version?
I just created a build using the VC.NET 2003 compiler/linker with version
1.1.9 of GDAL, and Xerces 2.5.0, and Jasper 1.700.5
The code I am using it with was build with the Multi-Threaded DLL C-Runtime
(\MD and \MDd compiler options)
So I rebuilt Jasper and GDAL with those settings.  I ran into a strange
error when creating a debug build where the resulting GDAL DLL had both the
debug and non-debug versions of MSVCRT linked into it.  This was causing
runtime asserts.  The only way I found to fix this was to explicitly tell
the linker to ignore the non-debug version of MSVCRT.  Has anyone seen this
before and could possibly shed more light on it for me?
Thanks
David M. Schulze
(207) 846-7111 x2482
david.schulze at delorme.com
DeLorme Publishing
2 DeLorme Dr
Yarmouth, ME, USA
www.delorme.com
