[Gdal-dev] s57 / s52
Christian Gebauer Tveen
cgt at navicon.dk
Tue Apr 20 16:29:03 EDT 2004
Thank you both for the nice responses.
By a glance it looks very nice. I'll look into it and hopefully I can
use it in my work. Someday I'll finish my api, to contribute back.
Regards Christian
s duclos wrote:
>Hi,
>I'm working on the s52 plugin for OpenEV.
>The CVS files are changing almost every day.
>So pulling the tree right now might not give you
>the best result.
>I'll commit today (hopefully) a cleaned-up update.
>I solve the last *big* S-52 rendering difficulty
>yesterday that needed geospacial query (postGIS)
>by using OpenGL selection mode.
>So we're getting closer to a poor man ENC viewer self
>contain in a single lib (libS52.so)
>Note that the code does low level S-52 rendering.
>Some could call it an 'S52 kernel' because upper
>layer need to be coded to 'drive' this code. For
>exemple if one what only the 'display base' objects.
>At the moment I render/dump everything comming form
>OpenEV (OGR) on the screen.
>Cheers,
>Sylvain.
>--- Frank Warmerdam <warmerdam at pobox.com> wrote:
>>Christian Gebauer Tveen wrote:
>>>Hello,
>>>I'm about to write some s57 rendering stuff using
>>the ogr sw. I wondered
>>>if anybody has any sw or knowledge on where to
>>look for sw that renders
>>>the s57 in s52 format. I have a prototype
>>rendering the data, but still
>>>misses the data layering, proper colouring and
>>data reduction + if
>>>necessary caching/tiling of data.
>>>I would very much appreciate any leads on where to
>>look.
>>Christian,
>>There was a bunch of work done implementing S-52
>>style rendering in the
>>OpenEV application. If you were to browse the
>>OpenEV CVS tree you would
>>find the S52 stuff in the contrib/S52 directory. I
>>don't think the S-52
>>rendering support is enabled in any of the stock
>>OpenEV binary releases.
>> http://openev.sf.net/
>>The rendering is implemented via OpenGL calls in
>>OpenEV.
>>Best regards,
>>I set the clouds in motion - turn up | Frank
>>Warmerdam, warmerdam at pobox.com
>>light and sound - activate the windows |
>>http://pobox.com/~warmerdam
>>and watch the world go round - Rush | Geospatial
>>Programmer for Rent
>>_______________________________________________
>>Gdal-dev mailing list
>>Gdal-dev at remotesensing.org
>>http://remotesensing.org/mailman/listinfo/gdal-dev
>Do you Yahoo!?
>Yahoo! Photos: High-quality 4x6 digital prints for 25¢
>http://photos.yahoo.com/ph/print_splash
