[Gdal-dev] Mrs ID driver for VC7
Andrey Kiselev dron at ak4719.spb.edu
Fri Apr 23 02:30:23 EDT 2004
On Thu, Apr 22, 2004 at 04:14:28PM -0600, Chapman, Martin wrote:
> I have a thirty day trial of the Mrs. Id driver for windows VC++
> Version 7.  How do I link it to the GDAL lib?  Are there instructions
> somewhere on how to do this?  I also read on the user group that there
> may be issues with the V7 driver from Lizardtech and GDAL because GDAL
> was written to bind to the VC6 version of the mrsid lib.  Is this an
> issue?
It is all the same for GDAL what compiler version will be used, bacause
GDAL comes with full source code. It is completely defined by the DSDK
binaries you have which you can't rebuild. The main problem is in API
version. GDAL currently supports MrSID DSDK 3.1.x and 3.2.x. Newest
version (4.0) are not supported yet due to completely different API.
> I am using GDAL 1.1.9.
There are was few fixes in that driver in GDAL 1.2.0.
						Andrey
Andrey V. Kiselev
Home phone:  +7 812 5274898  ICQ# 26871517
