[Gdal-dev] Different UTM Zones...
Tyler Mitchell
tylermitchell at shaw.ca
Sun Aug 8 00:52:43 EDT 2004
> At first I want to thank you for the quick response!
Any time.
> However, I do not want to use existing utilites, but I want to write the
> code by myself and integrate it into an application.
> I found some interesting information on the GDAL webpage.
> Am I right, that the OGRSpatialReference and the
> OGRCoordinateTransformation classes provide services both to transform
> between lat/long and projected coordinates and between different
> projected coordinate systems?
Well, that will work for your vector stuff anyway. Spatial reference systems
in general are served by GDAL's OSR class, if I recall correctly.
Tyler
