[Gdal-dev] Re: the debian directory needs a resync (and a little
update)
Silke Reimer
Silke.Reimer at intevation.de
Mon Aug 9 04:48:58 EDT 2004
On Fri, Aug 06, 2004 at 08:56:50PM +0200, Alessandro Amici wrote:
> - add support for netcdf and sqlite.
> - move tiff support to external library (finally added to debian!)
> diff -ur ../debian/gdal-1.2.0/debian/control debian/control
> --- ../debian/gdal-1.2.0/debian/control 2004-07-31 20:30:08.000000000 +0200
> +++ debian/control 2004-08-06 20:50:46.000000000 +0200
> @@ -2,7 +2,7 @@
> Section: science
> Priority: extra
> Maintainer: Silke Reimer (MoinMoin) <silke at intevation.de>
> -Build-Depends: debhelper (>> 4.1.25), zlib1g-dev, libcfitsio-dev, libpng12-dev, libjpeg62-dev, libungif4-dev, libhdf4g-dev, postgresql-dev, postgresql-client, libxerces21-dev, unixodbc-dev, python-dev, python-numeric, doxygen, d-shlibs
> +Build-Depends: debhelper (>> 4.1.25), zlib1g-dev, libcfitsio-dev, netcdfg-dev, libtiff4-dev, libpng12-dev, libjpeg62-dev, libungif4-dev, libhdf4g-dev, postgresql-dev, postgresql-client, libxerces21-dev, unixodbc-dev, libsqlite0-dev, python-dev, python-numeric, doxygen, d-shlibs
> Standards-Version: 3.6.1
> Package: libgdal1
> diff -ur ../debian/gdal-1.2.0/debian/rules debian/rules
> --- ../debian/gdal-1.2.0/debian/rules 2004-07-31 20:30:08.000000000 +0200
> +++ debian/rules 2004-07-31 21:33:01.000000000 +0200
> @@ -20,9 +20,9 @@
> --mandir=\$$\{prefix\}/share/man \
> --with-threads \
> --with-grass=no \
> - --with-libtiff=internal \
> --with-geotiff=internal \
> - --with-xerces
> + --with-xerces \
> + --with-sqlite
> # Patch the generated libtool to avoid passing -rpath when linking,
> # and to explicitly link libraries against the libraries they
Thanks Alessandro. I added all your changes. As soon as Frank is
back from vacation I will hopefully get back the possibilty to write
to CVS. Then I will check in my changes.
Many greetings,
Silke
Silke Reimer
Intevation GmbH http://intevation.de/
FreeGIS http://freegis.org/
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/gdal-dev/attachments/20040809/1e836f7c/attachment.bin
