[Gdal-dev] Correction to gdal_merge.py
Frank Warmerdam
warmerdam at pobox.com
Mon Aug 23 11:06:08 EDT 2004
Mario Beauchamp wrote:
> Hi all,
> I noticed that the projection information was not written to the output file.
> Looking at the code, it became evident why: there is no SetProjection().
> So simply adding:
> t_fh.SetProjection(file_infos[0].projection)
> after line 404 does the trick.
> Hope this is useful to someone :)
Mario,
I have applied this.
Thanks,
and watch the world go round - Rush | Geospatial Programmer for Rent
