[Gdal-dev] Correction to gdal_merge.py
Mario Beauchamp starged at videotron.ca
Sat Aug 21 20:20:14 EDT 2004
Hi all,
I noticed that the projection information was not written to the output file.
Looking at the code, it became evident why: there is no SetProjection().
So simply adding:
t_fh.SetProjection(file_infos[0].projection)
after line 404 does the trick.
Hope this is useful to someone :)
Mario B.
