[Gdal-dev] gdal_translate question
Frank Warmerdam
warmerdam at pobox.com
Thu Aug 19 12:45:12 EDT 2004
David W. Lowther wrote:
> Frank,
> I'm not sure that was/is the issue.
> Certainly I am not that familiar with GDAL, but I added four lines after
> calculating src_win to calculate the ABS of the values, recompiled, and
> it fixed my issue.
> Thoughts?
David,
It certainly sounds like the source window was your issue though your
fix won't give you the correct results.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
