[Gdal-dev] caching of the blocks
Fri Aug 27 13:38:44 EDT 2004
Stephane Routelous wrote:
> Hi Frank,
> Thanks a lot for your quick answer.
> I need to use the ReadBlock to have the best performances, and also because
> of the resampling.
> I will continue to use it and implement my own cache mecanism.
Stephane,
Note, you can call RasterIO() at 1:1 resolution on exact block boundaries
and you will have essentially the same performance but with GDAL block
caching kicking in.
Best regards,
