[Gdal-dev] caching of the blocks
Stephane Routelous
route at cae.com
Fri Aug 27 13:58:06 EDT 2004
Hi Frank,
I've done a performance test for comparing RasterIO vs ReadBlock
I'm reading a big geotiff image (8100x7200)
the results are : RasterIO=8752ms ReadBlock=6776ms
Stephane
-----Original Message-----
From: Frank Warmerdam [mailto:warmerdam at pobox.com]
Sent: Friday, August 27, 2004 1:39 PM
To: Stephane Routelous
Cc: 'gdal-dev at remotesensing.org'
Subject: Re: [Gdal-dev] caching of the blocks
Stephane Routelous wrote:
> Hi Frank,
> Thanks a lot for your quick answer.
> I need to use the ReadBlock to have the best performances, and also
because
> of the resampling.
> I will continue to use it and implement my own cache mecanism.
Stephane,
Note, you can call RasterIO() at 1:1 resolution on exact block boundaries
and you will have essentially the same performance but with GDAL block
caching kicking in.
Best regards,
I set the clouds in motion - turn up | Frank Warmerdam,
and watch the world go round - Rush | Geospatial Programmer for Rent
