[Gdal-dev] missing io.h file?
Norman Barker normanb at comsine.co.uk
Thu Dec 2 11:24:44 EST 2004
I had this error yesterday, just edit out the format as follows
(from http://www.remotesensing.org/gdal/gdal_building.html)
If you find build problems with one of the format drivers that you don't
care about, just remove the format from the GDAL_FORMATS line at the
bottom of gdal/GDALmake.opt, do a make clean, and make. This will drop
it from the build and default runtime registration.
Norman
Gillian Walter wrote:
> Hi,
> I just tried building the latest gdal CVS on fedora core 1 linux, and
> it failed once it hit the ilwis data format.  It gave this traceback:
> In file included from ilwisdataset.cpp:29:
> ilwisdataset.h:29: warning: ignoring #pragma warning
> ilwisdataset.h:30: warning: ignoring #pragma warning
> ilwisdataset.h:38:17: io.h: No such file or directory
> ilwisdataset.cpp: In function `std::string TrimSpaces(const
> std::string&)':
> ilwisdataset.cpp:49: warning: comparison between signed and unsigned
> integer
>   expressions
> integer
>   expressions
> ilwisdataset.cpp: In member function `void IniFile::Load()':
> ilwisdataset.cpp:180: warning: comparison between signed and unsigned
> integer
>   expressions
> Is there supposed to be an io.h file somewhere in gdal?  I couldn't
> find it there or among the standard system files.
> Gillian
> Gdal-dev mailing list
> Gdal-dev at xserve.flids.com
> http://xserve.flids.com/mailman/listinfo/gdal-dev
Norman Barker
Software Engineer
ComSine Ltd
Tel: +44 (0)1483 457121
Web: http://www.comsine.com
*Please Note:*
This text is confidential. If you are not the named addressee, it could be unlawful for you to read, copy, distribute, disclose or use the information contained herewith. If you are not the intended recipient please telephone +44(0)1483 457121.
