[SPAM] [DETECTED] [Gdal-dev] JPEG2000
Julien Demaria
dem at acri-st.fr
Wed Dec 8 12:01:24 EST 2004
Hi Jim,
You can do that with :
gdal_translate -of JP2KAK -co QUALITY=100 in.tif out.jp2
see here :
http://www.remotesensing.org/gdal/frmt_jp2kak.html
Regards,
Julien
At 00:20 08/12/2004, Jim LeMieux wrote:
>Content-class: urn:content-classes:message
>Content-Type: multipart/alternative;
> boundary="----_=_NextPart_001_01C4DCB3.6448B36F"
>Hello I was trying to use OpenEV to convert a GeoTIFF to a JPEG2000
>(Kakadu version apparently) and It works using the Export utility, however
>the quality is degraded significantly and there are no options to set the
>compression. I tried the gdal_translate at the command line and got the
>same results (didn't find any command line options to set
>compression). I'm looking to find a free compressor to compress all my
>GeoTIFFs to JPEG 2000 format at the lossless rate.
>Any suggestions?
>THANKS in advance.
>Jim LeMieux
>Kalispel Tribe
>_______________________________________________
>Gdal-dev mailing list
>Gdal-dev at xserve.flids.com
>http://xserve.flids.com/mailman/listinfo/gdal-dev
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20041208/fb28086d/attachment.html
