[Gdal-dev] undeclared identifier in netcdfdataset.cpp
Jack Varga
jvarga at boulder.net
Fri Dec 10 04:33:58 EST 2004
I'm wondering if this problem might be related to stricter enforcement
of ISO/ANSI standards in gcc/++ 3.4.1, (default compiler for my distro,
Mandrake 10.1). I don't know where the undeclared identifier is
attempting to be referenced from. Any suggestions or ideas would be
appreciated. I'm using version 3.5.1 of netcdf.
make[2]: Entering directory `/home/builder/gdal-1.2.5/frmts/netcdf'
/bin/sh ../../libtool --mode=compile /usr/bin/g++ -Wall -O2
-I../../port -I../../gcore -I../../ogr -I../../alg
-I/usr/include/c++/3.4.1 -I../../port -c -o ../o/netcdfdataset.o
netcdfdataset.cpp
/usr/bin/g++ -Wall -O2 -I../../port -I../../gcore -I../../ogr
-I../../alg -I/usr/include/c++/3.4.1 -I../../port -c netcdfdataset.cpp
-fPIC -DPIC -o ../o/.libs/netcdfdataset.o
netcdfdataset.cpp: In constructor
`netCDFRasterBand::netCDFRasterBand(netCDFDataset*, int, int, int)':
netcdfdataset.cpp:117: error: `nc_inq_var' undeclared (first use this
function)
netcdfdataset.cpp:117: error: (Each undeclared identifier is reported
only once for each function it appears in.)
netcdfdataset.cpp:128: error: `NC_INT' undeclared (first use this function)
netcdfdataset.cpp: In member function `virtual CPLErr
netCDFRasterBand::IReadBlock(int, int, void*)':
netcdfdataset.cpp:157: error: `nc_inq_varndims' undeclared (first use
this function)
Jack Varga
