[Gdal-dev] Installing GDAL
Frank Warmerdam
fwarmerdam at gmail.com
Fri Dec 10 11:43:20 EST 2004
On Thu, 9 Dec 2004 17:30:31 -0600, pasa0101 at stcloudstate.edu
<pasa0101 at stcloudstate.edu> wrote:
> Hello,
> I am trying to install GDAL in my computer using Visual Studio .NET 2003
> command prompt. I am assuming that I don't have to run vcvars32.bat for
> this. I did cd to GDAL root directory as per the instruction in the website.
> But when I type the command
> C:\GDAL> nmake /f makefile.vc, I got the error message that nmake is not
> recognized as an internal or external command, operable program or batch
> file.
Samir,
In fact, if you didn't have the Visual Studio install setup your environment
variables globally,you will need to run vcvars32.bat in the shell before
you can use the compiler.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
