[Gdal-dev] Re: Problems installing GDAL 1.2.5 - Crashes on Make
Sean Gillies
sgillies at frii.com
Fri Dec 10 12:27:21 EST 2004
On Dec 10, 2004, at 8:14 AM, Frank Warmerdam wrote:
> On Fri, 10 Dec 2004 07:52:32 -0700, Ethan Alpert
> <ealpert at digitalglobe.com> wrote:
>> Something is missing in the first -I. According to Sean G. mysql is
>> set to
>> be on by default but William has no mysql so the include files for it
>> are
>> not found. It's definitely a bug in the gdal configure.
> Ethan / William,
> The mysql problem doesn't normally manifest like this, but you might
> want to try configuring "--without-mysql" to ensure that isn't the
> problem
> you are having. The "bare" -I is likely the problem. If necessary
> you can
> just go into GDALmake.opt and remove it from the appropriate variables.
Frank,
On my FC 2 system lack of installed mysql did result in a bare -I.
Configuring --without-mysql, as you recommmeded, solved it.
cheers,
Sean
Sean Gillies
sgillies at frii dot com
http://users.frii.com/sgillies
