[Gdal-dev] trivial (?) optimization for gdal.i:GDALReadRaster()
Alessandro Amici
alexamici at fastwebnet.it
Wed Feb 4 11:07:39 EST 2004
Frank,
> i think i know where the remaining memmove-memset are sitting (see
> pytmod/gdalnumeric.py:154), but i have no work-around for that.
as far as i can understand there is no practical way to avoid the additional
memmove inside fromstring() (unless gdal actually provides it's own Numeric
extension module).
things would be much beter with numarray because you can fill a buffer object
with GDALReadRaster and build the python array object on top of it without
the additional copy. do you see a port of gdal/pymod to numarray in the
forseeable future?
cheers,
alessandro
