R: [Gdal-dev] trivial (?) optimization for gdal.i:GDALReadRaster( )
Thu Feb 5 16:43:12 EST 2004
Andrey Kiselev wrote:
> On Thu, Feb 05, 2004 at 05:18:00PM +0100, Vincent Schut wrote:
>>I'm sorry but I don't know how to invoke gdb to debug a python script,
>>so I don't have much more information.
> It is easy.
> $ gdb python
> and then 'run /path/to/script.py' in the debugger's command prompt.
> 						Andrey
Right,
The only thing I would add is that it can be hard to set breakpoints
in GDAL since the shared library isn't loaded when python is in it's
main().  Sometimes I introduce a wait call at some strategic point in
GDAL (ie. GDALAllRegister()) to give me a chance to control-c gdb after
gdal has been loaded ... then I can set a breakpoint.
Best regards,
