[Gdal-dev] OGR, SHP, and multi-polygons
Frank Warmerdam
warmerdam at pobox.com
Fri Feb 6 00:59:56 EST 2004
Ben Discoe wrote:
>>From: Frank Warmerdam
>>Patches were introduced in the fall some
>>time to try and classify rings properly and form correct
>>multi-polygons when reading from Shapefiles.
>>This did not exist in GDAL 1.1.9 so you will need
>>a nightly snapshot.
> OK, does that mean it now does the following?
> 1. For each polygon 'part', tests the winding order to determine if it's
> external or internal
> 2. If more than one external part is found, a OGRMultiPolygon is created,
> otherwise a OGRPolygon.
Ben,
The above is correct.
> 3. As it can't know in advance, the layer reports geometry type as
> "Polygon", even if there might be MultiPolygons inside.
I see it still reports the layer as type Polygon when they should likely be
Geometry since they may have polygons or multipolygons. This is technically
a bug.
> Some related questions:
> Is 'wkbPoint25D' the OGR equivalent of SHPT_POINTZ, or does OGR just use
> wkbPoint with 3 coordinates instead of 2?
wkbPoint25D is the equivelent of SHPT_POINTZ. Note that interlally there is
only one OGRPoint class. It returns a wkbPoint25D type if the z is non-zero
otherwise it returns wkbPoint as the type.
> Is there another GDAL release planned? My 1.1.9 is dated 2003-06-27, 7
> months ago.
It is my intention to produce a 1.2.0 at some point in the near future; however,
I have mostly just been directing people to the nightly snapshots for most
purposes. The 1.2.0 release will move to use of libtool by default.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
