[Gdal-dev] Please suggest a vector format for wireless application
Roger Bedell
roger at pocketterra.com
Sun Feb 8 10:51:52 EST 2004
Can the GML be sent using compression? Also, for several years I've been
interested in a similar application, but the traffic routing is dynamically
determined in real time using feedback from the velocity and direction GPS
data from a large number of vehicles. Is anyone working on such a scheme?
I've called it the "Velocigram" but haven't had the time to work on it much.
Roger Bedell, President, Sylvan Ascent Inc.
roger at sylvanascent.com
505-758-7712
www.sylvanascent.com
www.pocketterra.com
-----Original Message-----
[mailto:gdal-dev-admin at remotesensing.org] On Behalf Of Fu Chen
Sent: Sunday, February 08, 2004 6:53 AM
To: gdal-dev at remotesensing.org
Subject: [Gdal-dev] Please suggest a vector format for wireless application
Hi!
I wanna create a simple application for traffic management department in my
city to broadcast the situation on the road. This application will help
driver make his best route and ease the trafic block.
The data is very simple, the most important is main road's position, its
name, and the situation on the road which can be some levels for example 0
for free road and 5 for total blocked road. Some other layers can be include
if the space permit. The mobile device will get the road map in once and
then contact the host for the realtime road situation in some time gap.
Now I must select a format for a space and bandwidth limited mobile device.
GML seems a good selection for webgis. But it will waste a lot of bandwidth
to transport tag. Is there a simple compact binary format suite my design.
Hope some guru in this list will give me some suggestion.
Thank!!
Gdal-dev mailing list
Gdal-dev at remotesensing.org
http://remotesensing.org/mailman/listinfo/gdal-dev
