[Gdal-dev] missing libproj.so
Matt Wilkie
matt.wilkie at gov.yk.ca
Wed Feb 11 15:11:01 EST 2004
Hello Listers,
I'm attempting to run gdalwarp on a tiff image with GCPs which is not
"north to top". I get the error message
ERROR 6: Unable to load PROJ.4 library (libproj.so), \
creation of
OGRCoordinateTransformation failed.
I thought proj.4 is installed with gdal, is this not the case? "locate
libproj.so" comes up empty (and the locatedb is current).
I'm running gdal-cvs-040211 on cygwin-winxp; installed with "./configure
&& make && make install".
thanks in advance,
matt wilkie
Geographic Information,
Information Management and Technology,
Yukon Department of Environment
10 Burns Road * Whitehorse, Yukon * Y1A 4Y9
867-667-8133 Tel * 867-393-7003 Fax
