[Gdal-dev] Updated MrSID Driver
Johan A. Goossens goossens at saclant.nato.int
Tue Feb 10 08:31:46 EST 2004
Frank,
Attached are an updated version of the MrSID driver and VC-7 Makefile. They
have been changed to be compatible with the new 3.2.1 MrSID DSDK. I've
tested it on a Windows XP platform and successfully used gdalwarp on a
number of MrSID files.
You also need to change nmake.opt and configure since the libraries are now
in ${MRSID_DSDK}/lib (not in $MRSID_ DSDK}/bin/lib).
Regards,
Johan Goossens
Type: application/octet-stream
Desc: not available
Url : http://lists.osgeo.org/pipermail/gdal-dev/attachments/20040210/6c27b10d/mrsiddataset.obj
Desc: not available
Url : http://lists.osgeo.org/pipermail/gdal-dev/attachments/20040210/6c27b10d/makefile.obj
